Wiring diagram for B
WES KING
03-30-2005 09:34:04
Where can I find a wiring diagram for a 1950 AC "B" that has a distributor rather than a magneto? The tractor starts and runs good but the generator is not charging the battery. I rewired and I think I have the regulator wired wrong because the generator is rebuilt and should be good.
Thanks, Wes
Keith-OR
03-31-2005 21:10:33
 Re: Wiring diagram for B in reply to WES KING, 03-30-2005 09:34:04
Here is your wiring diagram....
HTH...Keith
Steve in N.J.
03-30-2005 17:47:54
Wes,
If you have a real voltage regulator mounted on the gennie and not a Reverse Current Relay (cutout), the way you wire in the VR is this way:
Ammeter minus- to Bat. terminal on VR Gen terminal on VR to "A" (Armature) stud on gennie
Field terminal (FLD) to "F" stud on gennie.
"L" terminal on VR not used if equipped
If your utilizing the OEM "cutout" it's wired this way:
Ammeter minus (-) to BAT terminal on cutout
Gen terminal on cutout to "A" stud on gennie
"F" stud on gennie to resistor on H/L switch If the gennie is rebuilt correctly, and the 3 position headlight switch is grounded correctly, it should charge. Make sure the H/L switch is grounded! That's how the system is designed. HTH
Steve@B&B
Rod (NH)
03-30-2005 15:57:34
Hi Wes,
As far as I know the B never had a true automatic voltage regulator provided by AC. I think that is the case for either a magneto or a distributor ignition. The OEM arrangement only had a generator cutout relay that automatically disconnected the generator from the battery whenever the engine was stopped. The regulation of the generator was done manually with the three position light switch in the instrument panel. There were only two generator charging rates...low and high when the engine was running, depending on the position of the light switch. The wiring diagram in the AC B/C service manual shows only the mag-equipped tractor. I would expect that the only difference is in the switching function in the wire connection to either the mag or the distributor. I think the generator charging circuit was the same in either case.
If you have a true regulator (two relays in one package) on your generator, I suspect that it was an aftermarket alteration by someone. I did that same alteration on my '42B until I decided later to simply convert to a 12V alternator. As I recall, it wasn't a difficult wiring installation. If you know that it is the original, externally grounded, third brush style generator, you might get some ideas from this article here at YT.
third party image Rod
JMS/MN
03-30-2005 12:36:20
Usually you can find the wiring diagram in the AC operator manual. Did you polarize the generator when you rewired the tractor?
Steve Clark
03-31-2005 11:44:10
 Re: Wiring diagram for B in reply to JMS/MN, 03-30-2005 12:36:20
I have a B- that seems to be having problems staying charged. How do you polorize the gennie and why. thanks
JMS/MN
03-31-2005 16:49:35
 Re: Wiring diagram for B in reply to Steve Clark, 03-31-2005 11:44:10
You should be able to find proper info in the archives. My simple explanation is you do it to tell the electrons which way to go. You use a short jumper wire and MOMENTARILY touch the battery terminal on the relay to another wire terminal on the relay and get a spark. I don't know if it is the field or armature terminal, I think it's the field, but if you touch to the wrong one you won't hurt anything. I think it magnetizes the field.
