after thought
jpuleo
10-21-2004 21:06:49
The rocher shaft was pretty worn down on the underside, so I fliped it over, Im not too clear on the exact path of the oiling system but mabey the gaps on top of the rocker shaft and rocker arm bushings is preventing oil from getting to the ends of the arms?
Dale(MS)
10-22-2004 05:20:40
 Re: after thought in reply to jpuleo, 10-21-2004 21:06:49
jpuleo, there is a stud that holds the rocker arm down that has a groove in it that allows oil to enter the rock shaft. You may have inadvertantly put it in the wrong place. It should be in the rear stud position with the groove facing the tee the oil travels in. Dale
