Figured it out. Still need help though
jpuleo
10-15-2004 15:59:14
It now strikes fine on engine block. Jumper wire held 1/4 in or less gets good spark aginst block when jumped off the copper plate that the brass rod in cap contacts. I know for sure Ill need a new cap and rotor. It still wont send a spark through a spark plug when hooked up to the jumper. Any Ideas why this might be? Mabey wrong kind of plugs? In new to magnetos.
Thanks
Rockin' Farmer
10-16-2004 04:18:05
 Re: Figured it out. Still need help though in reply to jpuleo, 10-15-2004 15:59:14
jpuleo,
Just happened to spot your post. I'm usually a JD guy, and I've had a #@%$ of a time with plugs in my '50 JD A with a Wico Mag. Been through Champion, AC, NGK and finally went to Autolite plugs. They seem to be doing O.K. Like Chad says, there must be something the others don't like about magnetos.
Good luck,
Rockin' Farmer
Chad Caswell
10-15-2004 18:52:43
third party image
I have heard that the Chimpanze (champions) Plugs are Junk. I had them in my Allis B and changed over to AC delco (45's I think....) And my motor ran alot better. Just a thought, I dont think the Chimpanzes work good with Magnetos.
Chad
