Continental n 62
Chuck MI
10-03-2004 19:48:50
Your G, and all stock G's for that matter, uses a Continental N 62 engine. I believe that the Massey Harris Pony also used that engine, and I am sure that there are other applications as well. You might be as well off to try to find another working or rebuild able N 62 as try to convert as I'm sure that that would be a more costly route.
Chuck
Stan(PA)
10-04-2004 09:17:26
 Re: Continental n 62 in reply to Chuck MI, 10-03-2004 19:48:50
Not sure, but I think I read something about the N62 having different mounting system for G and Pony. Check it to make sure before buying a Pony engine. The only other tractor I know of that used the N62 was the "Earth Master". It mounted same as the Massey Pony. Good Luck..... .Stan
Robert in W. Mi.
10-04-2004 19:12:32
 Re: Continental n 62 in reply to Stan(PA), 10-04-2004 09:17:26
Also the Farmall Cub has that engine, but i don't think it will swap in either.
I know where there's one with an old diesel in it. I'm not sure of the brand though, maybe a Lombardini???
The engine is the only thing i hate about my "G"!!
Robert
Chuck MI
10-04-2004 12:19:12
Thanks Stan, that's good info to know. I knew the parts were readily available, but didn't realize the mounting differinces. I'll file that in the arcives.
Chuck
