G allis engine swap
seabee(Ga)
10-03-2004 02:23:32
I have a G with rod through block. Is there any inexpensive fix useing a more common engine for a "play" tractor?
Seabee (Ga)
10-05-2004 17:48:08
 Re: G allis engine swap in reply to seabee(Ga), 10-03-2004 02:23:32
Thanks to all who responded. Its all food for thought.
Lil-Farmer
10-04-2004 15:48:28
Check the link.
Lil-Farmer
10-04-2004 15:50:33
 Re: G allis engine swap in reply to Lil-Farmer, 10-04-2004 15:48:28
Guess it's a banned link. Try this without the *'s
***www.ac-g-adapter.biz***
Chuck MI
10-04-2004 18:27:37
 Good concept in reply to Lil-Farmer, 10-04-2004 15:50:33
I like the concept. I wonder though if they are still in business, as the site hasn't been updated in over two years. Do you know of anyone who has one of these in use? Still a little pricey.
I'll try a live link
Chuck MI
10-03-2004 19:48:50
 Continental n 62 in reply to seabee(Ga), 10-03-2004 02:23:32
Your G, and all stock G's for that matter, uses a Continental N 62 engine. I believe that the Massey Harris Pony also used that engine, and I am sure that there are other applications as well. You might be as well off to try to find another working or rebuild able N 62 as try to convert as I'm sure that that would be a more costly route.
Chuck
Stan(PA)
10-04-2004 09:17:26
 Re: Continental n 62 in reply to Chuck MI, 10-03-2004 19:48:50
Not sure, but I think I read something about the N62 having different mounting system for G and Pony. Check it to make sure before buying a Pony engine. The only other tractor I know of that used the N62 was the "Earth Master". It mounted same as the Massey Pony. Good Luck..... .Stan
Robert in W. Mi.
10-04-2004 19:12:32
 Re: Continental n 62 in reply to Stan(PA), 10-04-2004 09:17:26
Also the Farmall Cub has that engine, but i don't think it will swap in either.
I know where there's one with an old diesel in it. I'm not sure of the brand though, maybe a Lombardini???
The engine is the only thing i hate about my "G"!!
Robert
Chuck MI
10-04-2004 12:19:12
Thanks Stan, that's good info to know. I knew the parts were readily available, but didn't realize the mounting differinces. I'll file that in the arcives.
Chuck
Tramway Guy
10-03-2004 18:17:44
The link didn't come through:
www.dieselacg.com
Dale(MO)
10-04-2004 09:33:46
 Re: G allis engine swap in reply to Tramway Guy, 10-03-2004 18:17:44
You said it when you said it's not cheap, but I have seen their site, and it looks like they do a bang-up job. Pretty slick, and well-engineered. If only AC had done the same thing, they would probably still be in business today!(We can always dream!LOL)
I have heard the same about the mounting difference between the G and the Pony. I don't remember what it all involves, but I have been told a Pony engine won't work - period. I would think a person could find a good core block and rebuild. I know it won't be cheap, but it would probably be the cheapest and easiest way to go. If you had an old clunker G that you didn't care about, and LOTS of time to tinker, that's another story. But, I would probably be apt to try to find a good builder. You may even find a good runner, you never know. Good luck!
Tramway Guy
10-03-2004 18:14:47
If you hadn"t said "inexpensive" you could have tried this one.
Lee in MI
10-03-2004 04:32:19
I've heard of some people putting in a toyota engine.
