B tractor
steve(ill)
09-23-2004 19:23:04
i though about bidding myself, but its a long walk to NY from Illinois.--- tractor has been setting a long time. if you are not going to work on it right now, maybe after the 15, then i would pull the plugs and pour each cylinder full of PB blaster, etc and let it set. put a tarp over the hood and muffler if it dont set inside. IN the end i would plan on tearing down the motor and wire brushing everything. You can probalby reshim the crank, lap the valves, buy new rings and a gasket set. Hone the cylinders, and pull the liners to install new o-rings. Its been seting a long time and deserves at least and economical overhaul before you start it up. Nice looking straight tractor. I have a couple of them and always looking for another B.
