Re: Open holes in final drives
JASON OWENS
05-10-1999 17:55:26
he is right the hole you see are in the bottom of the brakes the oil you see is coming from the axle shaft that goes to the differential more than likely. which could mean you have a bad roller brg. or just bad seals.at either rate neither are easy or fun to change.
