Open holes in final drives
chuck davis
05-10-1999 05:15:53
My 47 Wc has an open hole on both final drives.It does'nt appear to have threads.I assume these holes are not supposed to be open as gear lube is running out of them.I have a manual but don't see a plug or anything.What are they for,and should i plug them up? thanks
Jay Abrams
05-10-1999 21:19:41
 Re: Open holes in final drives in reply to chuck davis, 05-10-1999 05:15:53
Chuck, The WC final drive has a level plug for filling, and checking the fluid in each final drive. It is on the upper part of the lower half of the final drive, inside (away from the tire). Jay
JASON OWENS
05-10-1999 17:55:26
he is right the hole you see are in the bottom of the brakes the oil you see is coming from the axle shaft that goes to the differential more than likely. which could mean you have a bad roller brg. or just bad seals.at either rate neither are easy or fun to change.
Greg Ballantyne
05-10-1999 09:05:25
I have a '49 B. It too has open holes in the final drives. On my tractor the holes are for water drainage, if the tractor is out in the weather water will get in there and needs to come out. A couple of years ago I rebuilt parts of the rear end, bearings, seals, shims and brakes. The indicators the prompted me to do this were lube oil coming out where it shouldn't, extremely poor braking, and slight looseness of the rear wheels, I could push the top of the wheel toward the seat and it would move just a little. This was apparently caused by small critters nesting in the final drives, stopping the holes, and cutting off the drainage path. I now park the tracor under cover and check the holes now and then. I don't know if all this applies to you or not, but maybe it will help.
