Re: hyd. cylinder for WD
Dan D.
04-24-1999 04:38:29
Just get a regular ram from your farm supply store and put a vent in the one end for one way operation..better than cobbling up some two way system on the WD. Get the smalllest ram that you can that has the necessary stroke. That way the high pressure low volume system will lift the implement as fast as a high volume low pressure system.
BWH
04-26-1999 05:32:25
 Re: Re: hyd. cylinder for WD in reply to Dan D., 04-24-1999 04:38:29
Where do I get a vent for the cylinder? Checked at
TSC and they didn't carry anything like that.
Thanks for the help. BWH
Dan D.
04-27-1999 10:40:42
 Re: Re: Re: hyd. cylinder for WD in reply to BWH, 04-26-1999 05:32:25
You can get them at any farm supply store. They are just a plug that screws in where the second hose would go and the plug has a hole drilled through it to let air in and out. Any place that I've ever seen that sells rams has a bin full of these.
