Re: WD45 with steering stuck
Author |
cooper
07-13-2003 05:18:48
Check to see if the roll pin that holds the universal onto the shafts isn't hitting the oilpan. Check the support bracket for the forward shaft for binding(just in front of the u-joint)
cooper
07-13-2003 05:27:54
Re: Re: WD45 with steering stuck in reply to cooper, 07-13-2003 05:18:48
I just completely rebuilt the steering on my WD45 from the steering wheel to the front steering spindle shaft. I made my own parts to ensure tight steering. I encountered stuck steering when my young apprentice inserted a roll pin that was too long for the u-joint. There really isn't a whole lot that would cause binding.The worm and worm gear can be installed in a way that would create some difficulty. Also, if the front spindle shaft bearings have too much pre-load on them, it could add to the problem. Let us know what you come up with.....
ACEd
07-13-2003 08:51:30
Re: Re: Re: WD45 with steering stuck in reply to cooper, 07-13-2003 05:27:54
Thanks for info - I will check it out when I get a chance. I also have a WD45 single front that has other problems. May just try to swap front ends - do you know if that will work?
cooper
07-13-2003 13:01:30
Re: Re: Re: Re: WD45 with steering stuck in reply to ACEd, 07-13-2003 08:51:30
If you swap the entire pedistal it should.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
