Re: NAPA 1101 Oil Filter
Bob
07-11-2003 13:44:41
Make sure the riser tube from the filter base is still intact. I have seen tractors and Wisconsin engines using this type of filter where the tube has become dislodged from the base and lost... probably thrown away with an old oil filter?
I think the upper end of the riser tube is narrowed down to a small hole to provide built-in restriction to the flow of oil into the filter. Could any of these have been messed with... drilled out, etc., which would cause excess oil to be fed to the filter? Does anyone know what the original size oriface was?
RAB
07-11-2003 23:16:56
 Re: Re: NAPA 1101 Oil Filter in reply to Bob, 07-11-2003 13:44:41
Yes,Bob, they may have been, but I would not understand why.
All the same, The work Rod did was specifically avoiding any other change than the filter. Pretty damning on the manufacturer, who I would think, had perhaps better put right their mistake before blown engine repair bills start dropping in with their mail or they lose their market share, as these reports can have that effect.
Regards, RAB
