Re: 1939 B Hyd pump-lift
Mark
06-18-2003 20:07:49
With your tractor off, remove the relief valve plug. This is located on the top of your pump close to the the outlet port. There are 3 plugs on top of your pump, this is the odd one and the other 2 are similar and look alike. There is an insert in this hole that should be set 9/16" below the top of the hole. If it is less then that, the pump will relieve pressure too soon and I'm guessing that is the rattling noise you hear, and the reason for your lack of pressue. Take a 3/8" bolt with a nut threaded on it 9/16" from the end and tap the insert into place, the nut will set your depth. You may want to do this incrementally and periodically check for operation. Good luck.
