Re: AC CA hand clutch / finals problem
Tom Westerfield
04-28-2003 10:18:30
The brake and clutch housing on the right side are open both top and bottom. Unfortunately I have found that that area is a haven for mud dauber wasps. I've cleaned mine out almost annually. Your oil accumulation is likely from a seal leak where the shaft enters the differential. That isn't too hard to fix either. It does require the removal of a lot of stuff, i.e. the deck, etc. Seal from a local bearing shop is likely under $10.
