AC CA hand clutch / finals problem
Edward Mills
04-28-2003 07:13:39
I have a pair of AC CA tractors - both bought used and both had water in oil in area around hand clutch when I bought them. Looks like these are open under the platform on both sides. Shouldn't these be plugged or have a boot at hand clutch lever to keep water out? Also one did not have the platform - any idea where I can get one.
And finally the torque tube has been welded on top of one where it mounts to transmission - no idea how you can crack the torque tube, but I have access to parts C and B tractors - wondering if I can swap torque tube from either a B or a C?
steve
04-28-2003 15:15:46
 Re: AC CA hand clutch / finals problem in reply to Edward Mills, 04-28-2003 07:13:39
torque tubes are interchangaable, but the CA may have extra mounting bosses under the battery box area for belly implements. Maybe thats not important to you.
Tom Westerfield
04-28-2003 10:18:30
The brake and clutch housing on the right side are open both top and bottom. Unfortunately I have found that that area is a haven for mud dauber wasps. I've cleaned mine out almost annually. Your oil accumulation is likely from a seal leak where the shaft enters the differential. That isn't too hard to fix either. It does require the removal of a lot of stuff, i.e. the deck, etc. Seal from a local bearing shop is likely under $10.
