Re: CA oil pressure low
steve
04-24-2003 15:29:33
the filter on the B-C-CA has been known to change the pressure drastically. The oil in the CA does not go thru the filter and then to the motor bearings like a car. Allis has 15% of the flow bleads off thru the filter and returns to sump. IF the filter or tube in the filter is changed, or bad, you can drain more oil thru the filter to sump, and loss of pressure internal. MIght be worth a try to change it out.
