Re: Sixteen year old need's help on AC-B
steve
03-17-2003 17:03:11
at the right rear corner of the motor is a 1/4 inch pipe that comes up from the oil pump thru the rear of the eingine block. you need to take the elbow off the top of the pipe and crank motor a couple of revolutions and see if anything come out. if not, then pump oil into the pipe down to the pump with a squirt gun. probably the vibration of the motor during the trip home mad oil run back into pan and motor needs reprimed. Once oil is evident at this elbow, see if you have pressure. also loosen the small oil tube going to the valves in the head and see if it drips there. If you have oil, and the filter dont have it (pressure), then look at the tube in the filter.
