Re: Round balers fitted for a WD-45
Nathan (SD)
02-05-2003 08:56:35
I have used an IH 2400 behind a WD45. The main problem with that combo is the hills. On the flats it handled the machine easily. The only modification the tractor needed was the addition of a two way hyd valve. I rigged the return line to dump into the sump through the drain hole in the bottom so tou can still use your dipstick.
