Round balers fitted for a WD-45
Jim
02-04-2003 02:01:24
Could someone steer me in the direction of matching my WD-45 to a suited round baler? I only have found these in the 50hp and above class.
Dave K
02-05-2003 12:02:43
 Re: Round balers fitted for a WD-45 in reply to Jim , 02-04-2003 02:01:24
Pick up an AC Rotobaler, ideal for the WD!
Nathan (SD)
02-05-2003 08:56:35
I have used an IH 2400 behind a WD45. The main problem with that combo is the hills. On the flats it handled the machine easily. The only modification the tractor needed was the addition of a two way hyd valve. I rigged the return line to dump into the sump through the drain hole in the bottom so tou can still use your dipstick.
John (C-IL)
02-04-2003 10:02:13
Jim, The WD45 is really not suited to the operation of a modern round baler. I think that you will find the hydraulic system will seriously limit your activity with the baler. Remember, the 45 is high pressure/low volume with a single one way remote outlet. The baler will need low pressure/high volume hydraulics with a least one 2 way outlet and possibly 2 outlets. John
ksmith
02-04-2003 03:58:41
I asked my friend the same question. He has a hesston 530 ... makes a small bale although I don't know the size (I think there was an International baler made by the same company .... He feels the wd45 would handle it fine as long as you weren't doing hilly fields.
Hope this helps
Kevin
Jeff (SW Mi.)
02-05-2003 16:49:53
 Re: Re: Round balers fitted for a WD-45 in reply to ksmith, 02-04-2003 03:58:41
I agree the hydraulics would be lacking, could put on a front pump, problem solved. I know where a New Holland 848 round baler is for sale, makes 4"x4"(800lbs) bales, takes 40hp to run, the guy wants $4,000. I would suggest front weights on tractor too. Good Luck, Jeff
