Re: RE:need WDhelp please please please
Author |
Tom
01-31-2003 18:54:00
The knock in the transmission could be normal backlash in the gears. Some transmissions will make such a noise when the engine idles. It is caused by uneven engine speed taking up and letting off on the gears. If it goes away at a higher speed or when you have the tractor in gear and under load don't worry. Do you have good oil in the transmission? Maybe "tractor lube" which may be thinner than the 90 weight normally used in a WD transmission?
sHan
01-31-2003 21:05:02
Re: Re: RE:need WDhelp please please please in reply to Tom, 01-31-2003 18:54:00
dont have a clue what that nut put in it so after finding out what that so called oil he used i think im gonna drain it ALL and refill everything thanks sHan
Jerry
02-01-2003 17:07:59
Re: Re: Re: RE:need WDhelp please please please in reply to sHan, 01-31-2003 21:05:02
Gray oil usually means that it has water in it.
Ed
02-01-2003 21:19:47
Re: Re: Re: Re: RE:need WDhelp please please please in reply to Jerry, 02-01-2003 17:07:59
My shiter keeps falling out of pattern. Then I have to take the shifter lever out and use a screwdriver to get it back in neutral and go from there. I think the shifter forks are the problem. Does anyone know a site to get parts?
Tom
02-02-2003 18:27:14
Re: Re: Re: Re: Re: RE:need WDhelp please please please in reply to Ed , 02-01-2003 21:19:47
Also check end of shift lever, if it is worn it can contribute to this problem. You can build it up with brass or weld and file to shape.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
John Deere Tires And Rims, (1) Set Of Duals, Axle Mounting Hubs, Tire Size 18.4-38, Units Are Off Of A John Deere 4440 Tractor, Year Is Unknown
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
