RE:need WDhelp please please please
sHan
01-31-2003 18:45:52
Ok here is the good and the bad.. i plastigauged the rest of the berrings and they were all about .002 put it all back together and bought a new filter and oil and my oil presure came back to life it reads between the m&a on normal on the gauge i just bought this about 2 mo ago and the guy had changed the oil before i got it but i think he used 5 wt or somthing like that it looked like grey water anyway i chased the nock noise down to somewhere in the trans when it sits and runs if i put in the foot clutch the nock stops it has a bad manafold on it and kinda loud but the hand clutch doesent seem to make any diff in the knock in or out..ok took up enough of your time i leave you alone now...thanks for all the help on my other post...sHan
sHan
02-01-2003 21:02:43
 Re: RE:need WDhelp please please please in reply to sHan, 01-31-2003 18:45:52
THANKS GUYS FOR ALL THE HELP..... ...
Randy
02-01-2003 18:58:19
the throw out bearing has a grease fitting that is supposed to be greased every 8 to 10 hours. Check that. mine will get a slight knock if it's not greased regularly. get a flashlight and look up thru the inspection hole. you'll see the fitting on the left
Gordon Chance
02-01-2003 17:30:27
The knock that you are hearing is probably coming from a bad roller on the hydraulic pump. You will have to remove the pump to find and correct the problem. Gordon
Justin NY
02-01-2003 08:14:37
Shan, I just wanted to let ya know Napa had a recall on some filters that weren't creating back pressure per say to get correct oil pressure.I ran into that problem on a B after I rebuilt the engine and stuff I primed oil pump got alitle better psi ,Turned out to be oil filter changed that all was fine. Justin NY
Tom
01-31-2003 18:54:00
The knock in the transmission could be normal backlash in the gears. Some transmissions will make such a noise when the engine idles. It is caused by uneven engine speed taking up and letting off on the gears. If it goes away at a higher speed or when you have the tractor in gear and under load don't worry. Do you have good oil in the transmission? Maybe "tractor lube" which may be thinner than the 90 weight normally used in a WD transmission?
sHan
01-31-2003 21:05:02
 Re: Re: RE:need WDhelp please please please in reply to Tom, 01-31-2003 18:54:00
dont have a clue what that nut put in it so after finding out what that so called oil he used i think im gonna drain it ALL and refill everything thanks sHan
Jerry
02-01-2003 17:07:59
 Re: Re: Re: RE:need WDhelp please please please in reply to sHan, 01-31-2003 21:05:02
Gray oil usually means that it has water in it.
Ed
02-01-2003 21:19:47
 Re: Re: Re: Re: RE:need WDhelp please please please in reply to Jerry, 02-01-2003 17:07:59
My shiter keeps falling out of pattern. Then I have to take the shifter lever out and use a screwdriver to get it back in neutral and go from there. I think the shifter forks are the problem. Does anyone know a site to get parts?
Tom
02-02-2003 18:27:14
 Re: Re: Re: Re: Re: RE:need WDhelp please please please in reply to Ed , 02-01-2003 21:19:47
Also check end of shift lever, if it is worn it can contribute to this problem. You can build it up with brass or weld and file to shape.
