Re: AC WD question
Steve in N.J.
01-15-2003 18:01:55
Could be just worn out valve guides and you're loosing a little oil control windaging past the valves into the combustion chambers. Usually, if it's a ring problem, the engine will smoke more heavily, be down on power, and plugs come out pretty oil fouled. Did you do a plug inspection just to see what they look like?
Steve
sHan
01-15-2003 19:09:56
 Re: Re: AC WD question in reply to Steve in N.J., 01-15-2003 18:01:55
i pulled the plugs a wile ago i had 1 that was completly oil fouled and 1 that was prety bad shape. if i run a compression check what should the comp be on the cyls. thanks sHan
TX Denny
01-16-2003 13:05:08
 Re: Re: Re: AC WD question in reply to sHan, 01-15-2003 19:09:56
If they are all similar and around 70 to 100, you're in pretty good shape. If you have one fowling, I'd expect that one to lower than the rest.
