Thank you for the suggestion but I didn't remove the fan blade during installation. In re-examing the situation it appears as though the engine is offcenter such that the front is lower than it should be. The hand crank doesn't line up either. It looks like new engine mounts or customizing the radiator bolt holes in the frame.
Thank you for your help.
