Re: WD adjustable fan blade?
Phil Auten (TX)
01-13-2003 16:01:24
Greg,
That adjustment is for the fan belt width. Adjust it for the width of the belt you are using. It isn't used to move the fan back and forth. Sorry.
Phil
Greg in TX
01-13-2003 16:16:59
 Re: Re: WD adjustable fan blade? in reply to Phil Auten (TX), 01-13-2003 16:01:24
Thanks Phil,
I didn't figure it would be that easy.
Greg
JMS/MN
01-13-2003 21:30:52
 Re: Re: Re: WD adjustable fan blade? in reply to Greg in TX, 01-13-2003 16:16:59
You got some right answers as far as what the slots are for, but to make the adjustment, that's another thing. Take the unit off the tractor, remove the 1/4 inch bolts, and separate the two halves of the pulley. Typically the pulley has been 'adjusted' with a hammer and punch, which muchrooms the thin material it is stamped out of. grind off the mushrooming, and use emery cloth to get a smooth finish and the two halves should rotate easily when reassembled. A little graphite during reassembly doesn't hurt either.
JMS/MN
01-13-2003 21:31:48
 Re: Re: Re: Re: WD adjustable fan blade? in reply to JMS/MN, 01-13-2003 21:30:52
The slots also allow for a change in fan speed.
