Re: D14 power director and PTO question
Denny
01-06-2003 14:31:43
Joe, I see this is your second entry with no response so I suspect you are getting a bit anxious (with good cause). The low range on the power director is not related to the PTO. I will look through my manuals tonight to see if there is a reason for the low range issue. It could be that the "friend" burned out the low range clutch (never heard of this but I suppose it is possible). And I will look at the PTO drive train. What did your "friend" to it? Does the pto lever movement seem normal?
