Re: Stuck G Engine removal
Plant Doctor
01-04-2003 15:19:29
Mark: The hydraulics have nothing to do with pulling the engine from the transmission. It should slide right out. It does have two dowells pins right and left that can get very tight sometimes. The transmission imput shaft may be a little rusty where it slides in the clutch splines. Don't be afraid to use reasonable force to pry the engine from the trans. Make sure you have "ALL" the bellhousing removed.
