Re: Verifying where I am to add oil lift questions
Ric H. Ks.
01-03-2003 13:56:31
Engine oil goes in by dist on WD WD45 my ca takes it thru valve cover. lift raises when lever vertical lowers when horizontal on wd and WD45 to hold load at full lift position simply leave lever vertical, to hold at any mid position lower lever slowly to approx 45 degrees and you will feal a change in feel of movement that is hold psition, if this is not the case you need to set adjustments on controlvalve on top of pump. If your decals on battery box are readable you can get directions there otherwise you need a book
