Re: WC questions
Ron
12-29-2002 17:57:17
Assuming they are the same as the WD... The left one is the choke...rt one starter.. Belt pulley on a WD has 2 positions..loosten the set-bolt, and push it in (engine OFF) until the set-bolt will screw in place, and it will be engaged....reverse, to dis-engage..
jerry m
12-29-2002 18:16:38
 Re: Re: WC questions in reply to Ron, 12-29-2002 17:57:17
Starter rod is down bt trans.Both rods go to a common support under gas tank.One continues on to choke. The other stops at the support.Missing linkage? jerry m
