WC questions
jerry m
12-29-2002 17:48:31
Two pull rods on steering post. One for choke, other for ? How do you engage the belt pulley?
leadfoot phill
12-30-2002 17:27:04
 Re: WC questions in reply to jerry m, 12-29-2002 17:48:31
the one is a choke the other is the starter rod. to engage the PTO there should be a rod next to the differental disengager thingy :)
Noly
12-30-2002 05:02:54
one is for choke and the other is for magneto shutoff, might be missing some linkage. From what I have found this linkage is very rare and hard to find. I am looking for the linkage also Noly
Chris
12-29-2002 18:16:22
on my 41 WC one pull rod is for the choke and the other one grounds the mag to stop the engine
jerry m
12-29-2002 18:21:04
 Re: Re: WC questions in reply to Chris, 12-29-2002 18:16:22
Thanks Chris, that must be it.
Ron
12-29-2002 17:57:17
Assuming they are the same as the WD... The left one is the choke...rt one starter.. Belt pulley on a WD has 2 positions..loosten the set-bolt, and push it in (engine OFF) until the set-bolt will screw in place, and it will be engaged....reverse, to dis-engage..
jerry m
12-29-2002 18:16:38
 Re: Re: WC questions in reply to Ron, 12-29-2002 17:57:17
Starter rod is down bt trans.Both rods go to a common support under gas tank.One continues on to choke. The other stops at the support.Missing linkage? jerry m
Tom
12-29-2002 17:52:37
One for starter? PTO engage, WDs have a rod that comes up from a lever on the side of the PTO to about the right side of the steering shaft support.
chalmersbob
12-29-2002 18:19:43
 Re: Re: WC questions in reply to Tom, 12-29-2002 17:52:37
ON A WC THE SECOND ROD IS TO SHUT THE ENGINE OFF. IT GOES TO THE MAG WHICH HAS KILL SWITCH ON THE REAR (ENGINE SIDE) OF IT . THE PTO HAS A LEVER NEXT TO THE STEERING SUPPORT POST THAT YOU PULL TOWARD YOU. THE BELT PULLEY HAS TO BE ENGAGED BY LOOSENING A BOLT AND SLIDING THE PULLEY AND SHAFT TOWARD THE DRIVE SHAFT. SOME WC'S HAD A LEVER, PULL ROD TO ENGAGE THE PULLEY WHEN A CORN PICKER WAS INSTALLED (MOUNTED) ON IT. GOOD LUCK, HAVE FUN WITH YOUR WC.
jerry m
12-29-2002 18:37:31
 Re: Re: Re: WC questions in reply to chalmersbob, 12-29-2002 18:19:43
Thanks to all for the help!! jerry
