Re: Oops! Broke the starter solenoid on CA??? HELP!
David Maddux
12-26-2002 14:14:13
Laura: There is aperson on E-bay that sells hand cranks (new reproductions) for B&C allis trtactors I would think that they would work for a CA. I bought one for an old WC and they are good quality cranks The B and C cranks start around 19.50 I think. Better find out to be sure they would fit a CA. Dave.
CHALMERSBOB
12-27-2002 19:46:04
 Re: Re: Oops! Broke the starter solenoid on CA??? HELP! in reply to David Maddux, 12-26-2002 14:14:13
LAURA
A CA TAKES A LONGER CRANK THAN A B OR C BECAUSE THE FRONT END IS SETUP DIFFERENTLY. YOU CAN ASK THE SELLER ON EBAY IF IT WOULD WORK IF YOU GOTHAT ROUTE. I WOULD RATHER SEE YOU PULL THE STARTER AND HAVE IT REPAIRED. DO YOU RUN IT ON 6 OR 12 VOLTS? SOMETIMES ON 12 VOLTS THE STARTER HAS MORE TORQUE AND CAN DAMAGE THE STARTER. GOOD LUCK,BOB
