WD
external hydraulic reservoir
James
12-25-2002 16:27:44
I need to install additional hyd reservoir capacity on my WD to allow enough fluid to fully lift my new front end loader. What methods have you fellas used & how did they work out? Thanks.
Duey (IA)
12-26-2002 19:38:56
 Re: WD - external hydraulic reservoir in reply to James, 12-25-2002 16:27:44
James,
You should get with the guy that's taking one off a 45.
Dave Grubb
12-26-2002 08:07:25
You can tee a reservoir outlet hose into the bottom of the tractor at the reservoir drain plug. The one caution is that the extra reservoirs filler port must be at the same height as the tractor full level on the dip stick or the tractor reservoir will be overflowing. The tractor hydraulic reservoir case also has a vent into clutch housing so you could start putting hydraulic fluid into that area if you get the fluid levels above the intended dip stick levels.
