Re: WD 45 wide front
john
12-01-2002 09:51:48
dan and cory, i have scene wd wide fronts go for up to $600.00 if complete. ie;from front to rear pivot brackets and from center steering arm to hubs less wheels.post a price and i have a buddy that might be interesed in it. as for smirkey my wd wide front was in bad shape also.i cutoff both front and back pivot pins and made new ones then welded them into the frame assm.i replaced both front and back pivot brackets. however if only the pivot hole is worn i would bore it out and put in a bushing. if you are unable a local machine shop should be able to assist you.
