WD 45 wide front
DKase
11-17-2002 20:16:39
I have a wide front for a 45. New tie rods on one side, 4 bolt mounting. rebuilt pivot points, Buick wheels with 15" tires. What is it worth? It is in SD. Thanks DK
john
12-01-2002 09:51:48
 Re: WD 45 wide front in reply to DKase, 11-17-2002 20:16:39
dan and cory, i have scene wd wide fronts go for up to $600.00 if complete. ie;from front to rear pivot brackets and from center steering arm to hubs less wheels.post a price and i have a buddy that might be interesed in it. as for smirkey my wd wide front was in bad shape also.i cutoff both front and back pivot pins and made new ones then welded them into the frame assm.i replaced both front and back pivot brackets. however if only the pivot hole is worn i would bore it out and put in a bushing. if you are unable a local machine shop should be able to assist you.
dan and cory
11-20-2002 18:52:10
If its the square tube its worth more. In good shape its worth abuot $500. There getting hard to find ive been looking for one for a couple years. The round tube i have no idea.
smirkey
11-20-2002 18:27:20
how is it you can rebuild the pivot points on one. ours is getting egg shaped, drill and re-weld? use a bushing?
JMS/MN
11-19-2002 21:03:06
Most dealers/jockeys/salvage yards get upwards of $400 for an original ac wide front. Friends deal for less.
mike
11-19-2002 17:44:09
how much do you want for the 45wide front end I am instrested in it
Craig
11-19-2002 08:37:36
I'll pay ya $100 for it
shipping will be the problem
let me know
