Re: Hand crank vs. 12 volt start
Steve in N.J.
11-04-2002 11:24:10
Randall,
When you say sparks came out of the starter, do you mean out from the inside or from the battery cable lug? If it's sparking at the cable lug, it just may be corrosion causing a bad connection at the starter. I would clean all connections on both sides of the battery and starter and give her a whirl. It doesn't take long for moisture to get into the connections, especially if the tractor sits outside or in a shed. Also, take the starter motor out, and with a piece of emery cloth, sand the housing that fits in the bellhousing. This also increases starter potential because the starter self grounds itself in the bell. Hope this helps.... Steve B.
