Re: Slipping clutch on WD
Ron
10-29-2002 07:29:24
You may have a pressure plate with some weakening springs... You could take it out, and replace the springs...but you will need a press to re-compress the unit....!! I would install 9 springs, instead of the original 6... The late WD-45 pressure plate had all 9 springs, and have held well on mine, even with the power kit... Ofcourse, if there is oil..... .you can wash it down with brake cleaner, with the clutch locked dis-engaged...you won't get it all out, but, it should improve..!! 4x14" will put a major load on the clutches, and I depend on the foot clutch, to start with the plow in the ground...ya don't need any clutch slippage, when the front is off the ground, and you are steering with the brakes...!!!
