Slipping clutch on WD
Gary Beyer
10-28-2002 05:53:33
Well, the IT manual is absolutely no help on this. I have a slipping engine clutch on my WD. I tore it apart yesterday, and was surprised how good things looked. No burnt smell or discolored metal. The rivets were still well under the surface of the clutch disk friction material.
I replaced the clutch disk about 5 years ago when I rebuilt the engine. I did have trouble adjusting the clutch to get enough disengagement, and the tractor has always had a tendency to grind when changing gears. Otherwise, everything was fine until recently when the slipping started. The pedal had plenty of free play, so it's not an adjustment problem. I'm sure it was the engine clutch, because when the clutch was slipping, the PTO was not turning.
The clutch disk measures about .325" thick. I guess I'm suspecting the pressure plate. Any other ideas? By the way, it's the Rockford clutch, not the Auburn unit
Gary
Ron
10-29-2002 07:29:24
 Re: Slipping clutch on WD in reply to Gary Beyer, 10-28-2002 05:53:33
You may have a pressure plate with some weakening springs... You could take it out, and replace the springs...but you will need a press to re-compress the unit....!! I would install 9 springs, instead of the original 6... The late WD-45 pressure plate had all 9 springs, and have held well on mine, even with the power kit... Ofcourse, if there is oil..... .you can wash it down with brake cleaner, with the clutch locked dis-engaged...you won't get it all out, but, it should improve..!! 4x14" will put a major load on the clutches, and I depend on the foot clutch, to start with the plow in the ground...ya don't need any clutch slippage, when the front is off the ground, and you are steering with the brakes...!!!
punchie
10-28-2002 15:53:55
Hi Gary
Look at your forks that go againest the throwout bearing. Did you have trouble shifting? Was the tractor not moving or pto not turning?
Good luck !!
Punchie
Duey (IA)
10-28-2002 14:16:03
Gary,
While you have it apart, look in the bell housing above the clutch shaft. There is a small tapped hole. This is the hydraulic oil reservior breather. If at anytime, the reservior was overfilled, it will give the clutch a oil bath. I plugged this hole and installed a cylinder breather in the reservior cover under the starter. (welded a pipe coupler at an angle left of the starter)Inside, under this cover, is a small brass elbow screwed in the tapped hole. Duey
