Re: Stuck Wd engine I need help freeing it up!
steve
10-25-2002 16:02:36
one step at a time. --pull the starter and check taht it is not stuck
--use a pry bar thru the starter hole to try to turn the flywheel tooth by tooth.
--remove the valve cover and look at valves.
--tap each valve slightly with a hammer and see that it bounces down and back up, not sticking down.
--pull the oil pan and look at the bottom end
--pull the head off, see whcih piston is stuck.
--remove connecting rod caps one at a time and see when the crank starts to move--that piston is stuck.
--push up on stuck piston and push it out the top, hope the sleeve dont come also.
--if crank is stuck when connecting rods are loose, pull motor.
steve
10-25-2002 16:04:51
 Re: Re: Stuck Wd engine I need help freeing it up! in reply to steve, 10-25-2002 16:02:36
before you pull the pan or head, you might fill the cylinder with WD40 or PB blaster and let it set a few days to see if it can free the stuck rings (if piston is the problem)
