Dale(MS)
10-19-2002 07:04:11
Jim, If you are going to restore it I would tell you to get the manuals on the way.(can be ordered from this site or others). Start spraying every bolt on the tractor with your favorite penetrating spray. Get tractor in good spot in shop and start removing stuff. Put bolts,nuts,washers, etc. in zip-lock bags. Be sure to write something on the bag to in order to identify them later.Stare at tractor alot. Read everything you can find about your tractor. The WD and WD-45 are similar. Buy lots of tools! ( sockets,grinders with wire brushes,wrenches,hammers,saftey glasses,dust masks,air compressor with assorted tools,screwdrivers,torque wrenches,cutting torch,sand blasting equip,just to name a few. Don't worry these can be part of your wealth building/estate planning program.) Get dirty, have fun,be safe and hope the restoration bug doesn't bite to hard. P.S. there is something about orange that makes you feel good! Dale
