Re: Hydrolic oil level with new loader rams
David T (MO)
10-17-2002 06:38:04
What Steve says is true on 'most' tractors ;-) On the WD line the hydraulic level is checked with the rear lift rams extended fully. In your situation, more information is needed. If the loader rams are operated through an added flow-through valve and you have installed an oil return line to the reservoir, I would fill the reservoir to the full mark with the rear lifts fully extended and the loader rams at half-mask. If you are using the existing pump controls and no oil return, it will depend on the size of the loader rams. You'll have to judge what's best in that case. Filling the reservoir with the loader ram retracted and risk draining the reservoir when they fully extend, filling with the loader rams fully extended and risk overflowing the reservoir (which will spill into the engine clutch area) when they fully retract, or some compromise such as the half-mask approach I mentioned earlier. Good luck and let us know what works for you!
