Re: Best way to rig motor for removal-WD45
AL
10-10-2002 17:37:58
move the front pedstal ahead one set of holes..then you can lift the motor out...if you are nervous..use 2 head bolts to lift....an alternate method is to remove the left side rail and pull the engine that way...Al
ACSam
10-10-2002 17:44:44
 Re: Re: Best way to rig motor for removal-WD45 in reply to AL , 10-10-2002 17:37:58
How much would you figure the engine weighs? I think I'm facing the same situation. Thank You.
