Re: wd45 12v conversion
Duey (IA)
10-02-2002 17:59:25
Dale, I found the main reason for the automotive switch with acc. or diode, was to seperate the coil wire from the alternator wire, to stop the back feed that allows the engine to keep running when the switch is turned off. The indicater light will create enough resistance to use the feed back current and in effect, allow the engine to be shut down. A light or resister will also start the charging at a lower RPM as Steve says. Basicly, more than one way to skin a cat! Duey
Dale
10-02-2002 19:24:39
 Re: Re: wd45 12v conversion in reply to Duey (IA), 10-02-2002 17:59:25
Thanks for all the clarifications from everyone. I do appreciate the quick response on my question. I hope I can return the favor some day!
Dale
