Re: Will Idle all day, put in gear and she wants to stall...WD
Dave in Mo
10-02-2002 09:26:18
On my WD last week, I had a fuel supply problem similar to yours. Open the drain plug on the bottom of the carb float bowl and just watch the fuel stream. It should should not slow up even after the bowl is empty. If it does slow down to a trickle, you have found the problem. Mine was a small piece of silicone sealer had squeezed in somehow..... from a rebuild about a year ago!
