Will Idle all day, put in gear and she wants to stall...WD
Andy
10-01-2002 14:32:53
WD, will idle all day long, when I shift into gear, and start going, can't keep her from stalling, any ideas.....thx in advance
Dan in IN
10-09-2002 09:14:26
 Re: Will Idle all day, put in gear and she wants to stall...WD in reply to Andy, 10-01-2002 14:32:53
Does it run better if you choke it 1/2 way? If so, you have an air leak on your carb someplace. My D-17 did the exact same thing, I had to buy a new carb to fix it.
Trent Williams
10-06-2002 19:39:02
My D14 ran fine all summer. Got it out yesterday, and it did like yours. 1/4 turn on the carb. mixture screw and off I go. Air temperature change will change the mixture. Cooler air needs more fuel, warmer air takes less.
DoubleC
10-04-2002 10:48:22
Look up for my advise.....clean your governor weights..... seriously
Dave in Mo
10-02-2002 09:26:18
On my WD last week, I had a fuel supply problem similar to yours. Open the drain plug on the bottom of the carb float bowl and just watch the fuel stream. It should should not slow up even after the bowl is empty. If it does slow down to a trickle, you have found the problem. Mine was a small piece of silicone sealer had squeezed in somehow..... from a rebuild about a year ago!
Mark/Ks
10-02-2002 05:16:09
I agree with that it is a gas problem. First thing I would check is to see if it has good gas flow from the tank to the carb. I'm betting you have a blockage in the gas flow..
karl f
10-01-2002 23:12:16
could be bad/old gas too...
Ron
10-01-2002 19:26:08
Might be that it is not getting enough fuel from the power needle...is it opened up enough.?? Will it go "rich" and die, if you turn it out.??? If not, clean out the carb bottom...
Ted Seifert
10-01-2002 17:29:08
Sounds like a fuel problem. the outlet of the tank may be partially blocked
willie
10-01-2002 17:28:11
Andy
had similar problem with my recently purchased wd.
for test purposes-first of all, will it pick up some speed when you open throttle without trying to move?? if it does, ignition probably ok, but new points & plugs always a good investment. next step tie a string on the governor to carb link rod.then tug LIGHTLY while letting out the clutch. if this helps, it suggests governor problem. governor service is fairly easy, see par 120 in your I&T shop manual. former owner of my wd did some sloppy work, one of the weights was rubbing on pin, spent about an hour on it, now barks like I remember them doing when they were new.
good luck
Willie
Dave K. (Fl)
10-01-2002 16:52:29
Mine did that and it was simply a bad condenser.
Dave
Andy k
10-02-2002 18:41:04
 Re: Re: Will Idle all day, put in gear and she wants to stall...WD in reply to Dave K. (Fl), 10-01-2002 16:52:29
if u do find that its a gas flow blockage an inline gas filter did the trick for me even tho the sediment bulb gets most of it some still slips threw.
