Re: D21 hydraulics
Craig MO
09-17-2002 16:19:55
The flow divider in the pump is probably stuck or plugged with material. The suction screen could be sealed over with sludge.
Johannes
09-17-2002 17:41:44
 Re: Re: D21 hydraulics in reply to Craig MO, 09-17-2002 16:19:55
I have not yet received the service booki for the D21, how difficult is it to clean the suction screen or the flow divider in the pump?
Can you provide a short description or should I better wait for the book?
THANKS
Johannes
P.S.: today it magically worked again so your explanation makes perfect sense!
steve
09-17-2002 18:13:50
 Re: Re: Re: D21 hydraulics in reply to Johannes, 09-17-2002 17:41:44
might also drain off a quart and look at the oil. might have picked up some condensation. might be worth changing out the oil.
Johannes
09-25-2002 14:38:46
 Re: Re: Re: Re: D21 hydraulics in reply to steve, 09-17-2002 18:13:50
Thanks! The oel change almost did the job. Almost because the steering now works much better (half throttle) however the hydraulic is still uite weak. I am afraid that the old oel has done some damage.
What to do? Do I need to rebuild the hydraulic pump? If so are their kids for the D21?
