Re: WD45 RPM's
Doug in OR
09-13-2002 19:49:16
You can't go wrong if you open up the throttle, and then adjust the governor until the PTO is turning at 540 RPM. Around here, they allow 10% above manufacturer's rated RPM - so in that case, you could have the PTO turning at 594 RPM.
Jim in NC
09-14-2002 03:26:06
 Re: Re: WD45 RPM's in reply to Doug in OR, 09-13-2002 19:49:16
The rpm's on the PTO are in the operator' manual.
At high idle(1677 to 1722 rpm's)the PTO rpm's are 656 to 674. The 540 pto speed is at 1400 rpm's. Get it close, go to the pull and get them to check it.
