Re: Square bailing
Author |
Jim E
09-10-2002 20:27:08
Get a bigger tractor-with live PTO. I've been trying to bale with my WC but keep running into some thick spots, breaking the shear bolt on the baler and then have to retime the baler.
Jim in Michigan
09-13-2002 19:11:39
Re: Re: Square bailing in reply to Jim E, 09-10-2002 20:27:08
Jim E, you shouldnt have to retime after shearing a pin,, something else must be wrong,,what kind of baler is it, I have used about all types of NH, a few JD , a Ford and a Massey,, and have never had to retime after a shear pin breaks,,, We bale now with either a WD45 or the Farmall H, but have used the 8n with no trouble.,.. I think the C will bale if you are careful,,,Jim
Jim E
09-14-2002 05:55:28
Re: Re: Re: Square bailing in reply to Jim in Michigan, 09-13-2002 19:11:39
See my last post-Thanks for the insight, I'll work on the baler some more Sunday.
Eldon
09-10-2002 21:07:17
My grandpa used an 8n Ford on a square baler for years.....so I;m sure a B or C in good running condition will handle one. You might have to go slower or make smaller windrows. Make sure you are at the number of strokes per minute that the manual calls for. Jim I think if you are having to retime the baler everytime you shear the bolt you are shearing the wrong one. The one on the flywheel should go first.....
Jim E
09-11-2002 18:50:32
Re: Re: Re: Square bailing in reply to Eldon, 09-10-2002 21:07:17
The one on the flywheel is the one I keep breaking.
Trevor
09-12-2002 08:38:53
Re: Re: Re: Re: Square bailing in reply to Jim E, 09-11-2002 18:50:32
The baler timing should not change if the flywheel shear bolt breaks. (At least that is the way our Massey baler was.) Shearing that bolt is no different from shutting off the PTO or shoving the clutch, it is just a little harsh. My 2 cents
Eldon
09-12-2002 17:27:25
Re: Re: Re: Re: Re: Square bailing in reply to Trevor, 09-12-2002 08:38:53
My point exactly.....I haven't seen a baler that gets out of time by shearing the pto bolt. I would sell a baler like that real fast!
Harold
09-11-2002 19:05:04
Are you using OEM shear bolts and keeping them tight? I tried grade 8 bolts and kept shearing them till I got regular shear bolts. Keeping them tight also helps. My 2cents worth.
Jim E
09-12-2002 19:35:50
Re: Re: Re: Re: Re: Square bailing in reply to Harold, 09-11-2002 19:05:04
Yep I'm using shear bolts and I'm keeping them tight when I replace them. I haven't had the baler too long and some of the problems may be my inexperience. My biggest problem is breaking strings or knots. When they break I go back and try to rebale on the next round. Then I hit a large pile of hay, snap the shear bolt and if I'm lucky I just clear out the chamber and replace the bolt otherwise.....I also had the dealer clean up a lot of things (flywheel clutch, knotter, knives) and I've greased, replaced teeth, belt, grease fittings blah blah blah. The baler was sitting for a while ($50 auction) and it's getting better but like a friend said it needs to run a while to work things out. Thanks for the comments though!! I'll keep tinkering
Tom
09-13-2002 18:26:48
Re: Re: Re: Re: Re: Re: Square bailing in reply to Jim E, 09-12-2002 19:35:50
How much power are you using? I know a WD 45 would break the sheer bolts on a JD 24T without even trying if you got to a heavy spot in the windrow and didn't let out the hand clutch for a few seconds to let the baler digest the additional hay. What I am saying is maybe you have more power than necessary and expect the baler to handle more than it can?
Jim E
09-14-2002 05:52:19
Re: Re: Re: Re: Re: Re: Re: Square bailing in reply to Tom, 09-13-2002 18:26:48
My WC has around 25-30 hp. I'm not running it at full throttle (ground speed a little too fast)but I am keeping the baler ram speed close to where it should be. The baler is an IH/McCormick 37.
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Restoration Story: 1951 Farmall H - by The Red (John Fritz). I have been a collector of Farmall tractors since 1990 when I first obtained part of the family farm in Eastern Indiana. My current collection includes a 1938 F20, 1945 H, 1946 H, and the recently purchased 1951 H. This article will focus on what I encountered and what I did to bring the 1951 NEAR DEATH Farmall H back to life.
... [Read Article]
Latest Ad:
2 old Dodge Pickup Trucks not running mostly complete early 50s flathead 6cyl stepside box side entry hoods Price 1200 both.
[More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
