Re: 12 tires on a Little Allis G
steve
09-05-2002 18:46:45
MillerTire.com has 11 or 12 inch rims 28 inch diam for less than $100.each. I see that the stock 30 inch with 7 inch wide would be something like 28 inch diameter 12 inch wide. problem is the tires will weigh three times as much. if you want the looks, o.k. if you want the pull, forget it. you dont have the HP, weight, or axle strength.
