Re: Only Firing on Two-Cylinders
Bus Driver
09-05-2002 17:25:13
Some really sharp thinking on the previous suggestions. In case it might help someone, here is my recent experience. Friend had Allis B that sat in the "dry" for 6 years. Engine could be turned by hand crank. Points corroded. When cranked, was not running on #2 cylinder. Removed valve cover and discovered that exhaust valve was stuck open. The resulting clearance had allowed the pushrod to fall to one side. Took brass drift, ball pein hammer and lots of WD-40 sprayed on the valve stem. Tapped on the stem and the valve partially freed. Reinstalled the push rod and adjusted that valve clearance. Still missing that cylinder- adjustment now too tight as the valve had come completely free. Readjusted that valve, ran engine on all cylinders (YES!) and when warm, readjusted all valves. Running the engine without the valve cover will result in some oil spray on the tractor.
