HI Phil Frist I would think Scott is on the right track and after, tring these things, I would start looking into a major job of enghine work. Sound like plugs use AC if you can. In my wd's that oil them up, I use AC they will last about 4 times as long as champion Plugs. Normal for them to go out slowly, but if you were running her very slow, she may have done it fast. If you don't have new plugs sray with carb cleaner. Wire brush and spay with carb cleaner again. Take a knife and clean off the electrode ( that is the steel pin in the plug, sets under the arm or plug ground ) DON"T scrach the porclein ( glass ) spay one last time . Get sand paper or abrasive cloth and clean between electrode and the arm. Gap and sray with starter fiuld and let dry. You have got a plug with good chance that it will work for a short time. Sand blasting is the best, all most like a new plug. Next if it does not run right. Take all plugs out. Turn enghing over with your figure in the plug hole, becareful not to push too tight(don't get hurt), your see if the compression is there. If that is ok, then look at your wires. Not a fun job. You may get super charged LOL, Dam hot shock. One at a time take off of the plugs and see if they spark. By the way some times you can get a plug to fire this way, hold about 3/8" -1/2" away from plug and they often fire. Good Luck !! Be Safe !! Punchie
