Re: WD-45 start and idle
steve
09-01-2002 05:31:57
sounds like the intake manifold or gasket has a hole in it and you are leaking in air, or blowing exhauste into the air supply. of even simplier it could be plugged jet in the carburetor. might need a good internal jet cleaning.
Bob
09-03-2002 20:35:48
 Re: Re: WD-45 start and idle in reply to steve, 09-01-2002 05:31:57
This morning I was having the same problem with my Model "C". I removed and cleaned the carb, cleaned the inline filter and cleaned the tank out as much as I could, and drained it. In doing so I found that the tank had a lot of water in the gas apparently due to the heavy humidity lately. Once I put clean gas back in I added a bottle of Gas Dryer and it now purrs like a kitten. No more water in the gas.
Good Luck !
