Re: Allis Chalmers D12 hydraulic question.
Larry Ks.
08-22-2002 04:21:30
I can't technically answer your question (if that makes any sense), however....I just went thru a similar situation with a D14. Here is what my Buddy and I found out. There is some connection between the booster and the remote hookup. On mine, you could raise an implement with the remote, but then it wouldn't let it down. I hooked a hydralic guage on a short hose and we kept messing with the levers (I think you will have to definately hook up your other lever) Turns out. You have to have the booster lever in the lower position, once its there, then the remote worked just fine...its weird, but if you get the IT manual and read it, it explains this to some extent.
Larry Ks. again....
08-22-2002 04:25:24
 Re: Re: Allis Chalmers D12 hydraulic question. in reply to Larry Ks., 08-22-2002 04:21:30
After re-reading your question, I see I misunderstood what your trouble is. I'll look at my book when I get home and see if it makes and reference to it.
